LabWindows/CVI
I try to run tutorial ,but why not search "SinePattern" on Library ?
excuse me!
I'm rookie at CVI
I install CVI 8.5 evalution version that from NI's official website.
and I try to follow tutorial example , refer to "Geting Started with LabWindows/CVI.pdf"
I follow procedure & coding program step by step
but find a question !
on 3 chapter 3-2 page, I try to search "SinePattern" at Library Tree
No any match, whether or not I select "Show Function Names"
Does this library need external module?
Please give me any ideal or suggestion
thanks!
Message 1 of 9
(5,172 Views)
That function panel should be in the following Library Tree location:
     Libraries>>Advanced Analysis Library>>Signal Generation>>SinePattern
Which of these nodes are you missing?
Luis
Message 2 of 9
(5,153 Views)
Oh ~
I don't find this library , follow below path
First , I can't find "Advanced Analysis Library" folder.....
Would I install other module?
I only install CVI 8.5 evalution version
thanks!
Message 3 of 9
(5,137 Views)
Because you install evaluation version. Plz buy LabWindows/CVI Full version and you will see library.
Message 4 of 9
(5,121 Views)
Hi stockton,
Do you have the link that you used to download the CVI 8.5 evaluation copy? My guess is that you somehow got a link to the base copy instead of the full copy but I wanted to check what link you used to download the evaluation copy and how you found that link. Also, do you have just an Analysis Library category under the Library tree (Libraries >> Analysis Library)? This would indicate that you have a base copy.
Best Regards,
Message Edited by Jonathan N on 03-12-2008 11:57 AM
Jonathan N.
Message 5 of 9
(5,105 Views)
Hi Jonathan
thanks for your response
print screen :
http://img442.imageshack.us/img442/3860/cvilibraryyd4.jpg
http://img207.imageshack.us/img207/8342/cvireleasexr5.jpg
I just can't find Analysis Library path ..... others is exist
download's link for NI official website , as : ftp://ftp.ni.com/evaluation/cvi/pc/Full/NILWCVIFDS85.exe
detail size is http://img410.imageshack.us/img410/6238/cvisizerx2.jpg
thanks , best regards
Message 6 of 9
(5,089 Views)
Hello Mr. Ho.
After download & install, I can see advanced analysis ....
Try to download new copy & install to another PC....
Message 7 of 9
(5,068 Views)
Hello Mr. Ho,
The situation you're in is definitely unexpected. It looks as if CVI isn't loading any version of the analysis library. I'd like to investigate this some more to find out why this happened.
Would you mind navigating to your C:\Documents and Settings\All Users\Application Data\National Instruments\CVI85\bin folder, zipping up the contents of that folder, including the sub-directories, and attaching the zip file here? That might help us understand what is happening.
(if you're using Vista instead of XP, then navigate to C:\ProgramData\National Instruments\CVI85\bin instead)
Luis
Message 8 of 9
(5,055 Views)
thanks for everybody's care
I try to re-install CVI software
Library is appear!!!
but I don't know why
License status :
whatever , program can be coded , follow tutorial example
thanks for everyone's response
best regards
Message 9 of 9
(5,039 Views)
