LabWindows/CVI
I use some ringslides and when I want to choose some values which come from these ringslides, it runs. But, when I want to play a second time, it picks the same values. I don't know how to re-initialize these ringslides?
Ptit Seb:
You should be able to set the values either with slides with the SetCtrlVal() function. Alternatively, you could use SavePanelState() / RecallPanelState() to store the current values of controls on the panel and restore them later to their default position.
Good Luck,
Chris Wood
(2,887 Views)
