LabWindows/CVI
I want to access some of my function with keystrokes
I want to reach some functions using keystrokes. The reason is that these functions should be hidden for customers (I dont want to place them in a menu). What is the mest method to use?
(2,675 Views)
You can capture the keyboard events on the panel and check for which key was pressed, then respond appropriately. You would be using the EVENT_KEYPRESS in a panel callback.
Best Regards,
Chris Matthews
(2,675 Views)
