LabWindows/CVI
I want to know if I can use the vcl in borland C++ Builder 5 DDL that i want to use in a LabWindow project
If you are talking about the ActiveX controls and classes that you build UIs with in Borland C++ Builder, no these are not supported under the current version of LabWindows/CVI. In its current form CVI is not an ActiveX container IDE. However, the next release, 6.0, will support the use of ActiveX controls on UIs.
Jason Foster
www.ni.com/ask
(2,860 Views)
