LabWindows/CVI
I want to make a chart that records limit tests result in the sequence file view manager and I have no clue where to start.
I know that I have to make a call to first see if there is a limit test and I have done that but now I need to record the high limit, low limit, and measurement? I found an example here but when I am having problems organizing so that I am getting what I need from it. Here is the link I used below:
http://zone.ni.com/devzone/cda/tut/p/id/2700
There is an example on here for labview but none for cvi.
(2,997 Views)
I'm not sure I understand what you mean.
Where do you want to display this chart?  Just on your operator interface somewhere?
When do you want it to be updating?  At the end of the sequence, or as it is going along.
The report is already recording this data and displaying it in a chart, are you looking for something different from this?
What versions of TestStand and CVI are you using?  Are you starting from one of the user interfaces that ship with TestStand?
Kristen
(2,969 Views)
Yeah, I am displaying it on the executions tab. I want it to change as the sequence changes or it can do it at the end either/or. I am using TestStand 3.1 with LabWindows/CVI 7.1. Yes I am starting from the current user interface. I want to first figure out if a limit test exists if it does what are the limits and the measurement. I want to print those results to this chart. I don't want to pull them from the report because the report doesn't show til the end.
(2,964 Views)
