LabWindows/CVI
I want to programlly change column name in table of a panel
Hi everyone:
I want to programlly change column name in table of a panel, do you know the solution? which function should i use?
(3,274 Views)
If I follow your question, this should do it:
SetTableColumnAttribute (panel, ctrl, col, ATTR_USE_LABEL_TEXT, 1);
SetTableColumnAttribute (panel, ctrl, col, ATTR_LABEL_TEXT, "MyLabel");
(3,266 Views)
Thank you lan very much! and how about i want to programlly change default index of ring in a panel?
(3,245 Views)
