LabWindows/CVI
I want to set the value of multiple checkbox's in a for loop.
Can I do something like this?
for(i = 0; i < maxCheckBoxes; i++)
sprintf(tempBuff, "PANEL_CHECKBOX%d", i);
setctrlval ( panelHandle, (int)tempBuff, TRUE);
(3,586 Views)
SetCtrlVal() is looking for an integer which it will look up in the constants defined in the UIR .h file. Casting a string as an int doesn't look at the string as a symbol or constant name; it casts the ASCII string as an integer.
One way to set values of controls in a loop is to build an array of the constant names. It's an int array containing the values of the control constants (by constant name), not a string array containing the names. Make sure you use the control constant names, not their value from the UIR .h file: CVI can change those values anytime you edit the UIR file. For example, if your panel constant is PANEL and you have 5 checkboxes CHECKBOX_1 through CHECKBOX_5, your array difinition could be
int nCheckBoxes[] =
{PANEL_CHECKBOX_1,
PANE
L_CHECKBOX_2,
PANEL_CHECKBOX_3,
PANEL_CHECKBOX_4,
PANEL_CHECKBOX_5};
#define NUMCHECKBOXES sizeof(nCheckBoxes) / sizeof(int)
int main(int argc, char *argv[])
int SetAllHigh()
int i;
for (i=0; i nCheckBoxes[i] = 1;
See the attached example for more details.
(3,586 Views)
Thank you, that was very helpful and you were quick to answer.
(3,586 Views)
Thanks for the thanks (I mean you're welcome). It was a fun little question.
(3,586 Views)
