LabWindows/CVI
I would like to know : Does the NI6025E is compatible with LabWindows CVI 5.0 (Windows 95)?
And, Can I use it in 0-5V in input? Not in +-5V. If you have an answer, please send me an e-mail.
A French guy.
If it's Roberto who answers me, may you send me your mail adress. Thanks a lot.
(3,265 Views)
It's me. You can write me to roberto.bozzolo@eltra.net.
Now replies for you.
Yes, 6025E card is compatible with CVI 5.0 and Windows 95.
No, it's not possible to use it in unipolar acquisition or output mode. Either you manage to transform your sensor voltage range in bipolar mode or 11 bits are enough for your application and you can read in bipolar mode and discard all readings for V<0.
Hope that helps you.
Roberto
(3,265 Views)
Very good answer Roberto. But could you please remind my P'tit friend that he should upgrade to 5.5? It really has some nice features and it's only a couple hundred bucks isn't it? Seemed like it solved a number of issues for me.
Grant
Grant M. Johnson
Project Engineer
LECO Corporation
(3,265 Views)
The French guy:
If I have a good understanding of your questions, I would like to help you (if I could) but I couldn't 'cause my boss gave me this software and it is not possible to change.
I'm so sorry.
P'tit Seb.
(3,265 Views)
