LabWindows/CVI
I would like to use SCPI commands out of CVI using the VISA layer. Similiar to CWVISA but with out using the Active X control. Is is this possible and any good support links? Thx AJ
I was trying to use CVI to access the VISA layer directly without using IVI calls and just SCPI calls
and leverage the VISA layer.
(3,249 Views)
There is a C VISA library in CVI under the menu item Library->VISA.. It has all the functions to communicate with devices and send SCPI commands. Is that what you were looking for?
Best Regards,
Chris Matthews
(3,249 Views)
