LabWindows/CVI
ICommunication with windows usb
I need an example project to utilize the usb for communication with third-party vendors.
(3,334 Views)
You could use the VISA library for communication. Take a look at this trhead. It contains a link to a tutorial.
(3,320 Views)
What kind of device is your USB?
Does the device vendor provide any device driver and DLL module for the device?
The above link that Wim S provided is an approach that uses NI-VISA's USB RAW resource.  It assumes that the device has BULK-OUT and BULK-IN endpoints but no need for vendor's driver.  NI-VISA USB RAW hosts the device instead.
If the device vendor provides the device driver and DLL, you can use them through the DLL's function interface directly.
(3,313 Views)
