LabWindows/CVI
IMAQdx Error 80004005
i use LabWindows and Vision 2010 with IMAQdx vers. 3.7.
I need to control the registry setting of a Basler Racer camera with frame grabber PCIe-1429.
The acquisition through MAX works fine, but i have problem when open the camera in CVi using GenICam instructions.
When i call the instruction IMAQdxOpenCamera, i receive the error 0x80004005 (-2417467259), that is not listed in the errorr code of the IMAQdx.
Anyone had the same problem?
Thank you in advance
(4,058 Views)
are you able to run CVI Grab example?
How is the camera detected in Windows Device Manager?
Try to reinstall Vision Acquisition Software.
I hope this helps!
Bye,
Licia
(4,035 Views)
