LabWindows/CVI
INI file with section name without data
I have created an ini file using LabWindows CVI 2013 and want to create a section name that has no data similar to this:
[INTERFACE]
Interface Type = Serial
[GPIB]
[SERIAL]
Any ideas on how to create the [GPIB] and [SERIAL] sections without any data?
Also, is there a way to add comments to the the sectionName as well as to the tagName data?
(4,309 Views)
What have you tried so far?
Daniel Dorroh
(4,302 Views)
This is what I fould I had to do:
      /* create section names */
      Ini_PutInt(HandlerConfigObj, "GPIB",   "Dummy", 0);
      Ini_PutInt(HandlerConfigObj, "SERIAL", "Dummy", 0);
      Ini_RemoveItem(HandlerConfigObj, "GPIB",   "Dummy");
      Ini_RemoveItem(HandlerConfigObj, "SERIAL", "Dummy");
Seems like there should be a function to create just the section name.
(4,300 Views)
