LabWindows/CVI
ISSUE: greyed-out library file in LabWindows/CVI
I have been developing in LabWindows/CVI.
I did some code enhancements / improvements for an old project which uses the FT4222 library files:
ftd2xx.lib (64-bit)
LibFT4222-64.lib (64-bit)
I did not originate this old project which was started before I worked with this company.
Now, I have started a new LabWindows/CVI project from scratch where I also need to use those library files.
I did an explore directory for those files to find their location in the old project.
Without doing any installation, I simply copied over the whole folder to my own new project folder.
Then I added those "existing" library files to my project inside LabWindows/CVI.
Please see attached screenshot of the Library Files list on project explorer.  Notice how those particular library files are greyed-out?
This is not the case for the old project.
What have I missed or incorrectly done?
Please advise.
Thanks for the help.
MI
(1,935 Views)
Accepted by topic author mi7engr
Maybe your current build configuration is for 32 bits and those are 64 bit LIB files?
S. Eren BALCI
IMESTEK
(1,920 Views)
Hi Eren,
You are right.
My build configuration was set to 32-bit.  I switched to 64-bit and they are no longer greyed-out.
Many thanks for this help.
MI
(1,904 Views)
ftd2xx.lib (64-bit) Where can I download this file.
(1,286 Views)
Always go to the source. Since it is an FTDI chip, you need the according drivers from FTDI of course.
https://ftdichip.com/drivers/d2xx-drivers/
Rolf Kalbermatter  My Blog
(1,258 Views)
