LabWindows/CVI
IVI installer creation wizard
I am trying to create an installer for my IVI specific driver. I am using the "IVI installer creation wizard" under Tools menu. I have included
the .c, .h, .fp, .sub and .lib files. But, at the last step i am getting this error:
Error: Failed to add file to CAB file
Could anyone tell me what the mistake could be?
Thanks in advance,
Priya.
(4,087 Views)
Hello Priya,
Would it be possible for you to attach your driver files to this thread, or if you prefer, post them to our ftp site, so that we can try it out?
Luis
(4,076 Views)
Hi Luis,
I have herewith attached the files. Kindly change the extn from .txt to .rar, in order to extract the contents.
Thanks in advance,
Priya.
(4,062 Views)
Hi Priya,
Unfortunately, I wasn't able to reproduce the problem. I'm attaching the resulting .msi here (please change the extension from .txt to .msi
Which version of Windows and CVI are you using? One possible way to get this error would be if you didn't have permission or access your %TEMP% directory. Are you logged in as a user with administrator privileges?
Luis
(4,046 Views)
