LabWindows/CVI
If cvi can not support "extern" keyword ?
Hello ,
I have programmed such like codes :
//func1.c:
extern int something ;
void func1(void)
func2();
//func2.c
static int something ;
void func2()
something = 100;
func3();
//func3.c
void func3(void)
when building the program ,it always show a wrong message :"Project link errors ,Undifined symbol 'something' referenced in "func1.c " and "func3.c" . I'd like to know if CVI would not support the "extern" keyword ?
David
(3,037 Views)
Of course CVI supports extern.
If you declare a variable as 'static' (outside of a function), that means that the scope of the variable is local to the source file in which it is declared. So in this case, your 'func2.c' is faulty: you should omit the 'static' specifier:
int something;
Martin
Martin
Certified CVI Developer
(3,037 Views)
