LabWindows/CVI
If one or more booleans are pushed how can i run them in order of priority?
Hello to all,
I'm a student and my project is to design a frontpanel for an elevator. I have several booleans (floor request buttons) and  I want them to run in order of priority. How can I handle this problem?
(3,029 Views)
Hi JoyceJacobs, I would like to answer you but:
  1. Your reference to "booleans" let me think your question is related to LabVIEW: please note that this board is dedicated to CVI (C programming language) and you will hardly find here an exhaustive answer to LV-related questions
  2. I am sure your teacher has offered you the correct instruments to approach this problem: revise the concepts you have learned and you will find the correct answer Smiley Wink
(3,006 Views)
