LabWindows/CVI
If the table cell can not receive a virtual key?
Want to execuate a "copy/paste" function in the table control. I hope type the "Ctrl+c" to copy  text in a cell, but nothing to do with the "ctrl" key pressed.
David
(4,512 Views)
You could consider using ClipboardGetTableVals and ClipboardPutTableVals
(4,488 Views)
Hi Roberto,
The key problem is how to capture the virtual key pressed event in a table. e.g., how to capture the "Ctrl+c" or "Ctrl +v" in the EVENT_KEYPRESS case?
David
(4,480 Views)
Table can receive and trap Ctrl + someCharacter in keypress event: you can discriminate the keys pressed with this code:
if (event == EVENT_KEYPRESS) {
  if (GetKeyPressEventModifiers (eventData2) == VAL_MENUKEY_MODIFIER) {
    sprintf (msg, "Ctrl + %c pressed.", GetKeyPressEventCharacter (eventData2));
    MessagePopup ("Notice", msg);
else if (event == EVENT_VAL_CHANGED)
  MessagePopup ("Notice", "Cell value changed.");
Unfortunately, if the table is in edit mode Ctrl-C and Ctrl+V appear to be trapped by the system at low level and not to be passed to the control callback. Within CVI you can trap EVENT_VAL_CHANGED event, but I see no way to discriminate between a user type-in and a paste operation except for trapping whether a previous keypress event was received, which can be a troubled way to go. I can't see a way to trap Ctrl+C.
There may be a method to get those event using some windows API but I don't know it.
(4,459 Views)
