LabWindows/CVI
Illegal board ID error for PCI-7354 replacemnet
Hi everyone,
I have a system based on LabVIEW Real Time 10.0f2 with a PCI-7354 built in 2009, running until last week.
Now the controller stops working at the initialization of the four axis. We replaced everything after the PCI-7354, axis, cables etc. It seems the PCI-card is broken.
I have a working replacement here from another system. If I swap the cards I got an error 70012 "Motion: Illegal board ID. You must use the board ID assigned to your controller in Measurement & Automation Explorer."
Is there any way to use the replacement card without rebuilding the operating system?
I don't have experience with Labview at all and it seems we don't have all the sources to rebuild the system
Best
(4,001 Views)
First of all, you have posted to the LabWindows/CVI board while your problem relates to LabVIEW or better to Motion, so you should find the correct board ad post your question there: LabVIEW board, Motion Control and Motor Drives .
Having said this, and please consider that I'm not using neither LV nor Motion, from the error messag you see I suppose you can open Measurementand Automation Explorer program, find the defective device and look for a way to change the board ID that should be listed there. Sorry for not being able to address you more precisely to a solution, if any exists.
(3,989 Views)
(3,964 Views)
