i am using basler acA4600-10 uc camera device. if set the full 4608*3288 resolution image grabbing will reduces per seconds. but i use the half of the resolution that time will save the image per seconds(fps). i check my application log file " Image stream is in out of sync " show like and Camera block ID show -1 on particular time . how to solve this problem. can any one help to solve this problem.
