LabWindows/CVI
Implementing a data base
Hi.
I want to implement with CVI a personal data base (name, ocupation... anything).
First of all I have to visualize this data base and than to access any data from it.
What can you tell me about this subject?
Wich are my best choses?
Can I use a specialized program for data bases (ODBC) like mysql to work with CVI?
Thanks.
(3,836 Views)
It depends on wether you need to interface with an exsisting database or not. NI distributes a sql toolkit for CVI with wich you can connect and use several type of popular databases: I have used it to work with Acces databases and it works good, but I don't know if mysql is implemented in the toolkit.
If you don't have to connect and use an exsisting database and/or interface with other applications, you could even consider developing your own application for it:
. define a structure with all the fields you need. Consider having extra space allocated for adding new fields in the future without need to convert the file
. allocate an array in memory with the elements you need
. sort the array with qsort and perform searches with BinSearch functions
. display using a table control
. write/read to a file with fread/fwrite
For relatively small files (say less than 1000 records) it could perform well and it can be customised to your needs.
(3,813 Views)
Hello Tmaxial,
The LabWindows/CVI SQL Toolkit:
• Works with any provider that adheres to the ADO standard.
• Works with any database driver that complies with Open Database Connectivity
(ODBC).
In particular, you can use mySQL with CVI. In particular, the following document describes how to do this:
http://digital.ni.com/public.nsf/websearch/6257BDDBE5DC9BE886256D3A005697E3?OpenDocument
Also, you can obtain the SQL toolkit for LabWindows/CVI from www.ni.com. Here is a link to the SQL toolkit reference manual, if you decide to get it, or already have it.
http://digital.ni.com/manuals.nsf/websearch/D3DF4019471D3A9386256B3C006CDC78?OpenDocument&node=132100_US
Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
(3,803 Views)
