LabWindows/CVI
Impossible to run the program
Labwindows 13.0.1
My LabWindows/CVI application runs without errors on my development machine.  However, when I try building an executable and running it on a target machine, I receive an error that says "Unable to run the program". How do I fix this?
(4,538 Views)
Did you simply copy the executable or did you create a distribution kit? You may want to have a look here
(4,536 Views)
Thanks your help
I called the program to compile it from a backup done on a network disk. So, that seem it's not possible. It runs on the local disk.
christophe
(4,392 Views)
