LabWindows/CVI
In Labwindows, is there an easy way to make a string control display in hexadecimal, the way Labview would allow with a right click?
(3,568 Views)
Presumably you are actually displaying a number, so you could use a numeric instead of a string. Numerics can be set to display decimal, octal, hexadecimal formats, as desired.
JR (Hoping this is not another duplicated post...)
(3,563 Views)
Thanks.I did think of that. I'm trying to duplicate a Labview USB example that sends and receives. How would I convert the received string to hexadecimal?
(3,560 Views)
Ah - I think I'm with you now. I don't know Labview at all so I'll have another guess at what you want! Would something along the following lines be suitable:
    char line [100]
    char out [256];
    char segment [3];
    char *in;
    char c;
    out [0] = 0;                            // Ensure output line is blank
    in = line;                              // 'line' contains the received string
    while (c = *in++) {                     // Repeat until end of input string
        sprintf (segment, "%02X", c);       // Convert one character to HEX
        strcat (out, segment);              // Add it to the end of the overall string
    SetCtrlVal (panel, text_control, out);  // Print the string when finished
JR
(3,558 Views)
Thanks JR, that looks like what I'm looking for.
(3,553 Views)
