LabWindows/CVI
In labwindows, how to print the gridlines when I use the excel2000.fp?
thanks
(2,939 Views)
Hello
If I understand your question correctly, you want to format the excel gridlines so that when you print the excel sheet, you can see the individual cells.
You can do that by first selecting the area of interest by using Excel_WorksheetRange. After selecting the area , you would get the handle of the boders collection by using Excel_BordersItem and then set the property of the linestyle and weight of the line accordingly.
The VB help for the borders collection should describe the properties of the object. Here is a link to the help.
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/off2000/html/xlobjBorders.asp
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(2,939 Views)
