LabWindows/CVI
Including third party ActiveX controls into CVI setup
I am using a third party activeX control. I used the activeX to FP converter
to make an instrument driver. Now I made the distribution kit but activeX
control is not part of it. Is there any way with which I can include this as
a part of mys etup. I know one option is to call the setup.exe which came
with the ActiveX control and call it at the end of CVI isntaller.
vishi
(3,157 Views)
Hello
When creating the distribution kit for your CVI application, Select the "Install ActiveX Container Support", add the ocx file to your file group, and select the "Register Files as ActiveX servers". For more information on the options, click on the Help button on the "Create Distribution Kit" window in CVI.
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,157 Views)
