LabWindows/CVI
Incorrect errors from ConnectToTCPServer?
(CVI 5.5.1 on NT)
When I call ConnectToTCPServer() and the server wasn't registered yet, I get "Unable to register service" instead of "Server Not Registered" as expected.
Also, when the Address is a host name that may not be resolvable (local or DNS), I got "Invalid Parameter" and started hunting down a parameter mismatch in the call. I eventually discovered that the paramter was valid, but it was a simple case of "host not found."
Any word on these from the NI insiders?
(3,947 Views)
Ignore the first item about "Unable to register service." Profuse apologies!
(3,947 Views)
Hello Jon,
This error may be related to the buffer size being used. We have a KnowledgeBase article on this topic at http://www.ni.com >> KnowledgeBase >> Search for "+invalid +parameter +CVI +TCP".
If you have further questions, please feel free to contact us at http://www.ni.com/ask
Jeremiah Cox
(3,947 Views)
Thanks Jeremiah,
I guess I didn't find this article because I was searching for ConnectToTCP! However, it covers a slightly different case than mine, but the concern is the same, I'm sure.
Anyway, All works OK when the server is actually there, just the misleading error when it isn't. I also noticed the same response when the host is correct, but the port (service) is not registered. Fundamentally, there is an invalid parameter, but a similar error is given from other libraries (like UIL) with different meanings. I don't expect perfection, I just thought I'd bring to your attention.
Thanks for your response.
(3,947 Views)
