LabWindows/CVI
InetPing, Win7 and Two NICs
InetPing does not appear to work under Win7 when there are two NICs in the computer.
The node I am trying to ping is on the second nic.  InetPing always returns "not available", ie, Available = 0, for that node.
When pinging that node from the command line, it works every time, with 0 msec delays.
I  believe this was neve an issue under XP.
Is there any work-around?
(This is the second Win7 anomaly I have found.  The other one had to do with DAQmx function calls failing when the project directory was on a network shared drive.)
CVI 2013SP1
Message 1 of 1
(4,138 Views)
