LabWindows/CVI
InetTelnetOpen Multi
I use InetTelnetOpen in 4 thread each one have it's handle, I noticed that the time elapsed during a single thread in telnet is 2 sec but with 4 threads 9 sec.
Is there any solution to this problem?
Thanks a lot!
(3,662 Views)
NO reply !!!!
(3,632 Views)
There is another forum post that explains what may be happening here, linked below. Essentially, only one thread can execute a function in a library at one time, which is why 4 threads is taking longer.
https://forums.ni.com/t5/forums/v3_1/forumtopicpage/board-id/180/thread-id/16687/page/1
In addition, I would recommend reading through the following white paper on multithreading in CVI.
https://www.ni.com/en/support/documentation/supplemental/06/multithreading-in-labwindows--cvi.html#s...
Maggie M.
Application Engineer
National Instruments.
http://www.ni.com/support
(3,615 Views)
