LabWindows/CVI
Ini_dispose() problem : dynamic memory corrupt
hi,
i encountered this error message "Dynamic memory corrupt" at the
execution of Ini_Dispose(handle). the value of handle is still the
same at the Ini_New() function.
any idea of what is the problem ?
fabe
(3,262 Views)
Can you post a small example that demonstrates this problem? Did you try running the ini sample program? You can find this under ..\CVI\samples\toolbox\ini.cws. Are you able to reproduce it this the example as well? I know I've tested this example numerous times without any problems.
Bilal Durrani
NI
Bilal Durrani
NI
(3,262 Views)
