LabWindows/CVI
Input Matrix to the SymEigenValueVector Function
Fatal runtime error when a 2D Array is input to the function: eg:
"Array argument too small (44bytes). Argument must contain atleast 6720 bytes."
(4,278 Views)
Actuall, the input array must be 2D and it must be square (nxn same number of rows as columns). I tried it with a 2D 5x5 array entering 5 for size and it worked fine.
Best Regards,
Chris Matthews
(4,278 Views)
Thank you. However, does it matter whether the 2D array is created as a double pointer (** Input_Matrix) or as pointer to rows of the array (* Input_Matrix)?
I have a 2D nXn array: *Input_Matrix with n as the size, and I still get the error.
(4,278 Views)
2D arrays in C are NOT double**. A 1D array of double* is NOT a 2D array. 1D or multi-dimension numeric arrays are just double* to a allocated buffer of size (dim1*dim2*dim3...). That is why you are getting the problem. you need a single memory block with a double*, not an array of double* blocks.
Best Regards,
Chris Matthews
(4,278 Views)
Thank you!
However, I tried the following array on SymEigenValueVector and the Eigen Vectors that the pgm prints out, seem to be wrong.
If the input matrix should be a single memory block with a double *, how is the matrix read from this memory block (row-wise, or column-wise)?
int main()
int i, j;
double * array;
double * EValues;
double * EVectors;
EValues = (double *) malloc(2*sizeof(double));
EVectors = (double *) malloc(4*sizeof(double));
array = (double *) malloc(4*sizeof(double));
array[0] = 2;
array[1] = -1;
array[2] = 0;
array[3] = 1;
SymEigenValueVector (array, 2, 1, EValues,
EVectors);
Cls ();
for (i=0; i<2;i++) {
printf("evalues = %f\n",EValues[i]);
printf("===================
=====\n");
for (i=0; i<4;i++) {
printf("EVectors = %f\n",EVectors[i]);
return 0;
evalues = 2.000000
evalues = 1.000000
EVectors = 1.000000
EVectors = 0.000000
EVectors = 0.000000
EVectors = 1.000000
Thank you!
(4,278 Views)
It's in memory row-wise. So the array you are sending in is:
2 -1
0 1
Remember, this function says it is looking for a 2D array input. If you are mallocing and trying to mimic a 2D array, a good thing to do is declare a 2D array (double [][]), fill it, and look at it in memory with the Memory Display (Window->Memory Display) in double format. Then you will know exactly what a 2D array looks like in the memory buffer.
Best Regards,
Chris Matthews
(4,278 Views)
Thank you. If that is the case, should'nt my E.Vectors be
EVectors = 1.000000
EVectors = 0.000000
EVectors = 1.000000
EVectors = 1.000000
instead of 1,0,0,1 (as printed by the pgm) for the given input?
(4,278 Views)
