LabWindows/CVI
InsertTableRows causes crash on exit
I have a program that keeps data in a table. Every time the user presses the Add button, a row is created in the table and the data populated.
Everything works, except on exit. When I exit the program using the X in the corner, I get one of two things to happen:
1. R6025 - pure virtual function call
2. The dialog closes, but the IDE still says < < Running > > until I stop it manually. (This might be that the error dialog is behind another window. This case happens infrequently)
This is the line of code:
    InsertTableRows(pnlCal, pnlCal_tblData, -1, 1, VAL_CELL_NUMERIC);
Weird thing is that if I add only one row then the program exits normally.
I've tried deleting all the rows before the program exits but that does not help.
(3,030 Views)
That's not the problem. Please ignore the question.
(3,027 Views)
