11-26-2007 09:40 AM
Hi Rob,
I'm double checking into some of my thoughts before posting but one quick question is this. Before you upgraded to LV 8.5, you of course were using LV 8.0.1 boot disks. Now, at that time, where you able to use the Desktop PC boot disk without any problems? From your posts, it seems as if you were using the PXI boot disks even before upgrading to LV 8.5?
If that's true, it appears to me that you are still seeing the same problems in LV 8.5 with the issues of the PXI boot disks allowing you to install CVI support and the Desktop PC boot disks not allowing you.
Is that a correct assumption?
Best Regards,
12-13-2007 09:46 AM
Hi Rob,
Not sure if you are still looking at this post but I have been looking into the
CVI issue a little bit in terms of what is displayed in the LabVIEW Real-Time
Software Wizard.
For starters, all the items that show up in that wizard are taken from the <National
Instruments>\RT Images\ directory.  In CVI 8.0, we installed two cdf files into the
directory <National Instruments>\RT Images\CVI\8.0 directory called cvilvrt.cdf and
cvianalys.cdf.  MAX looks at these files to determine
what entries to display which in this case was
LabWindows/CVI Analysis 8.0.0 and LabWindows/CVI Run-Time Engine for
RT 8.0.0. Now, what I found was that those entries will ONLY be
display when the target is configured as a PXI system. There are RT target
codes inside of those files that say only display for PXI. So if you turned a
Desktop PC into an RT target, you should NOT see those entries at all. I
confirmed this on my end.
Now my thoughts are that you somehow (which I tried and wasn't able to) got a
Desktop PC to turn into a PXI system using some PXI boot disks. I don't believe
you should even be able to do this. If you did, then it would make sense that
those entries appeared.  To verify my thoughts here, could you post a zip
file of the RT-Images\CVI directory?
It really doesn't matter if you don't have those entries in the Wizard as you
can still use CVI DLLs with LV RT by downloading the windows\system32\cvi_lvrt.dll
file
to the ni-rt/system
directory or the ni-rt/startup/data directory. If you
are using analysis, then you would need to download <National
Instruments>\Shared\Analysis\nianalys.dll to one of those directories
as well.
Hope this makes sense
Best Regards,
12-21-2007 08:52 AM
12-21-2007 09:40 AM
 Fu-Shan Lin
			Fu-Shan Lin
			01-02-2008 04:45 AM
Dear friends:
After reading all those good questions and answers, here I would like to ask a "strange" question. The question is,
"Is is possible to transfer my applications, which is written with Labwindows/CVI 8.0.1, to ETS real-time system without NI Labwindows/CVI real-time module ? Of course, I have a evaluation version of ETS RTOS."
I had tried this way for around 1 weeks, I think the key point is Run-Time Engine(CVIRTE). For other program IDE, like VC++ MFC, VB, Borland, they can be downloaded into ETS RTOS system very easily, but the application built by CVI seems can not.
Can any friend encounter this problem ? Thank you a lot for any comment !
Fu-Shan Lin
01-02-2008 07:03 PM
 Fu-Shan Lin
			Fu-Shan Lin
			01-02-2008 09:47 PM
Hi, Jonathen:
Thanks for your quick reply.
I think I should ask the question in more specific way. I used Labwindows/CVI 8.0.1 as my development environment, and I have a evaluation version of real-time OS building software(ETS) on hand. Please be noted that it is not Labwindows/CVI RT module, but just ETS software only.
My question is,
(1) Can I download Run-Time-Engine of Labwindows/CVI on ETS RTOS without Labwindows/CVI RT Module ? If yes, any document reference ?
(2) Can I make a distribution kit to install my application into ETS RTOS target machine without Labwindows/CVI RT Module ? If yes, any document reference ?
Thank you very much for the reply. Comment from anybody else will be very appreciated, too !
Fu-Shan Lin
01-03-2008 04:21 PM
 Fu-Shan Lin
			Fu-Shan Lin
			01-03-2008 07:28 PM
Hi, Jonathan:
Thank you for your reply. I will contact local NI sales engineer for the quotation of RT module.
Fu-Shan Lin
