LabWindows/CVI
Install Error
Hello,everyone,
I distribute my program with the Dist.Kit, then install it, an error occured like showing in the image.It doesn't affect the executing of the program, but it still an error. I want to know why and how to solve it , anyone can help me?
OliveWiwy
2010.7.13
(3,783 Views)
It is not unusual for the version of the NI Uninstaller in your distribution to be lower than the one already on the system you are installing to. The error dialog you are seeing is not normally shown. Examining your distribution should help us understand what is happening. If possible, please zip it and post it to ftp://ftp.ni.com/incoming. Also, which version of CVI are you using?
Mert A.
(3,735 Views)
Hello,Mert,
Thanks for your help.I'am sorry that I cann't post the zip of our distribution to you,it is up to my boss. But the problem is solved now, I used CVI80 before, now I use CVI90 distribute my program, it works well, no problem any more. I don't know whether the version of CVI cause that problem, but it indeed works now.Thanks all the same!
OliveWiwy
2010.7.14
(3,724 Views)
