LabWindows/CVI
Installation stops when upgrading NI-DAQmx drivers
I am deploying a CVi  application since a couple of years under various CVI versions. Usually, going to a higher CVI version is rather seamless.
I switched from CVI2009 to CVI2012 recently. I created a new distribution kit with CVI2012.
When I run that kit over an existing installation created with CVI2009, this message pops up.
The DAQmx drivers on the previous installation (CVI2009) are:
with the CVI2012 version, it looks like this:
Since there's a rather large number of installations out there, I don't want to force my customers to manually uninstall the NI-DAQmx drivers, and then run my installation again.
So I guess my question is, - what can I do to avodi this?
Thanks for your help.
Best Regards,
Greg
(4,115 Views)
Hello Greg,
Prior to 9.0, the driver was always Full version, and it created a large installer that prevented applications that use DAQmx from creating run-times. From DAQmx 9.0, the driver was restructured to three distributions:
  • Core: Just DAQmx Runtime
  • Configuration: (With MAX and Runtime)
  • Full
Probably, the message showed up because you only included the Core distribution. Could you try to add the Configuration as well?
Carmen C.
(4,066 Views)
Hello Carmen,
thanks for your reply. I added the "NI-DAQmx MAX Configuration Support" to the installer. However, the same message comes up during the installation.
I then also added the third one, the "NI-DAQmx Application Development Support" and tried it again.
And this configuration works well. The installer runs through and updates NI-DAQmx without problems.
However, my distribution has now grown from 600MB to 1.6GB !!!
This is quite a lot, since we also offer the distribution through download.
So if there are other ideas that avoid the additional Gigabyte, they are most welcome.
Thanks again,
Greg
(4,047 Views)
