LabWindows/CVI
Installer TargetDir
hi all,
we build a distr-kit for everytime the same pc-configuration and I want to suppress the users possibility to change the target-path of the application and the RTE. is this possible anyhow ?
best regards
Simon
(3,986 Views)
If you have CVI 2009, you can just uncheck the box on the General tab labeled "Allow installation directory selection". If you are using an older version, you have to edit the setup.ini file (in same directory as setup.exe) after every build of the distribution: change "SingleDirectory=1" to "SingleDirectory=0".
Mert A.
(3,974 Views)
thanks, that did it.
best regards
Simon
(3,959 Views)
