LabWindows/CVI
Installing CVI6.0 and 7.0 on same machine
I need to use both versions on same machine. Can I do it?
vishi
(3,184 Views)
Yes you can. You will only have one Runtime Engine, that is backwards compatible, but both environments can live side by side on the same machine.
Jeff
NI
(3,184 Views)
What happens if I have to make distribution kits using version 6.0 if
RTE gets replaced by 7.0? Will my cvi6.0 kit use 7.0 RTE?
Thanks for your help.
vishi
> machine.
> Jeff
> NI
(3,184 Views)
The 6.0 distribution kit uses the cvirte.msm found in it's redist folder. Therefore, it will distribute the 6.0 RTE on a system that has no cvirte.dll or an older cvirte.dll.
If you build a distribution with a CVI 7.0 then this will take precedence and not allow any older RTE to install. This is by design, and why we maintain backwards compatibility.
The RTE above is what gets installed in your System folder and the environment uses at design time. there can only be one RTE on any given system, but the RTE can be shared between different environments.
Jeff
(3,184 Views)
