LabWindows/CVI
Integrate LabWindows/CVI Libraries into MS Visual C++
How to Integrate LabWindows/CVI Libraries into MS Visual C++? I tried to follow couple exemples, but nothing is working. The code do not compiles.
(3,406 Views)
Hi Trimble,
Have you checked out the Integrating LabWindows/CVI with Microsoft Visual C++ KnowledgeBase? That has some great information as well as links to other documents that discuss common issues when using CVI libraries in C++. Since you didn't mention the errors you were getting, I'll refer you to a couple other documents that tend to be issues with customers using CVI libraries in C++ which are the
LabWindows/CVI User Interface Updates Not Showing Up in Microsoft Visual C++ Projects and Receiving Error -86 When Using a LabWindows/CVI Static Library in Visual C++ KnowledgeBases.
Have you tried converting a sample project? What version of CVI and Visual Studio are you using?
Best Regards,
Jonathan N.
(3,402 Views)
