LabWindows/CVI
Intellisense
Hi there !
Since a few weeks, I'm Using CVI 8.0. I found that it has the new feature 'Intellisense' (I guess CVI 7 began first with it).
Now my question is: sometimes it doesn't work and I don't know why.
Today I had the effect that it worked, but my new added fields of a struct weren't visible.
Can someone give me further informations but this ? After what do I have to look in the Online-Help of CVI ?
(3,337 Views)
This data is built whenever you compile your project. So, if you add new fields to a struct, they won't be visible until the next time you compile. I assume this is the behavior you are seeing.
Hope this helps,
-alex
(3,319 Views)
