LabWindows/CVI
Interrupt generation and register handling in CVI
We are having NI CVI 5.0.1. We are trying to develop the drivers for NI 6014 card in win3.11 OS as the drivers for win3.11 is not availible by NI. In the same regard, writing data to registers like ax,bx,cx,dx, flags is required. In
borland C, the data can be written to registers through _AX,_BX, _CX, _DX,_FLAGS, which is included in dos.h. But, the same code in NI CVI gives error
undeclared identifier _AX,_BX, _CX, _DX,_FLAGS
Also, dos.h header file is not present in NI CVI.
Secondly, the generate interrupt function present in borland C is also not availaible in NI CVI.
Kindly suggest if it is possible to perform the above two operations in CVI 5.0.1 version i.e, generating interrupts and accessing registers.
(2,904 Views)
CVI is not designed to develop drivers, just applications. Therefore, you can't do some kernel functions such as generate interrupts in CVI. You can read and write to and from registers using CVI's inp and outp functions. You would need the HEX address of the register.
Best Regards,
Chris Matthews
(2,904 Views)
