LabWindows/CVI
Invalid use of '__declspec'
Hi, I am trying to compile a formerly builded project without changing anything. But I get the following error for function declarations in the header file.
int DLLSTDCALL DLLEXPORT Test_InitDevDll (int invertByteOrder);
"test.h"(36,16)   Invalid use of '__declspec'.
What can be the reason of this error?
(4,789 Views)
Accepted by topic author Rados
Try reordering it:
DLLEXPORT int DLLSTDCALL Test_InitDevDll (int invertByteOrder);
I assume you now use CVI 2013 with Clang which is more strict.
/* Nothing past this point should fail if the code is working as intended */
(4,775 Views)
Thank you very much it fixed my problem. In fact on my pc both CVI 2013 and CVI 9.0 is installed. I was building the project with CVI 9.0 but it was still giving error. Can the cause be the engine of 2013 ?
(4,772 Views)
