LabWindows/CVI
Invoking CallBack other than from UIR.
The UIR has a group of 20 buttons all associated with the same callback function. There is a case statement for each button which does a bunch of stuff when that button is pressed.
Here is the question:
While accessing statemachine code I need to simulate a UIR button press. Can regular code invoke (the above)  a callback function or is that taboo? I could have a dedicated function but it would be exactly the same as the callback function.
I don't know if this is recommended or not? LabWindows might not like it?
NOTE: When executing statemachine code all the above buttons are dimmed so that they would be inactive during the invoked call to the callback function.
Thanks for any insight.
(3,660 Views)
Accepted by topic author NI Nubie
Hello -
The function CallCtrlCallback in the Programmer's Toolbox should be exactly what you are looking for.
NickB
(3,658 Views)
That did it.
Thanks Nick.
(3,654 Views)
> CallCtrlCallback()
And you can also simply call it as a normal function, passing the correct
panel and control identifiers and whatever events you wish.
Guillaume Dargaud
http://www.gdargaud.net/
(3,590 Views)
