LabWindows/CVI
Is it possible to bypass individual methods when using the Activex Automation Controller Wizard?
I am using the Activex Automation Wizard, but one particular object has a method that causes the error, "Function Parameter is not Activex Automation Compatible." I don't need this particular function, but I need another method from this object, but because of this error, LabWindows will not let me create the .fp file.
I was hoping there was a way to tell CVI to ignore the particular method that I don't want to use. Any insight would be appreciated.
(2,935 Views)
What version of CVI are you using by the way?
You can turn off interfaces from being generated, but not individual functions in an interface. I would suggest editing the type library yourself and removing the functions that are using none-ActiveX data types. Otherwise, you won't have a wrapper and will have to use the low level ActiveX functions in CVI's ActiveX library.
Best Regards,
Chris Matthews
(2,935 Views)
