LabWindows/CVI
Is it possible to generate pulses on a ctr out and simultaneously read them on another ctr input using one NI PCI-6601?
I am trying to output a pulse train on ctr0 OUT and I want to receive them on CTR1 SOURCE of the same NI PCI-6601 card, but no use! 😞
The pulses are generated OK, but the acquisition fails within timeout (10 sec.). The generated signal has 1 Hz frequency and 20usec high time. I've studyed the NI examples for this.
Can anyone help me, please?
(4,377 Views)
Maybe you should post your code for us to see what could be wrong ?
(4,357 Views)
Hi Julien,
I can post the code, but actually, it worked! I was making a loop between CTR0 OUT and CTR1 SOURCE and it didn't work. I made a loop CTR0 OUT <-> CTR1 GATE and it worked like a charm! As far as I read in the NI PCI-660x manual, I cand loop to either SOURCE or GATE pins and the pulses' acquisition should work anyway.... Maybe I am wrong. Can you explain me why it didn't work on the SOURCE pin?
Thank you very much for your tine!
Marles
(4,353 Views)
Sorry but that's not clear for me. If anybody else has any idea ? ^^
Maybe you were using CTR1 SOURCE...despite a wire between CTR0 OUT and CTR1 GATE ???
(4,351 Views)
Yes, you are right. I was using a wire between CTR0 OUT and CTR1 SOURCE, and a wire for DGND (but this is not mandatory). This configuration didn't work. Only when I moved the wire between CTR0 OUT and CTR1 GATE it worked.
(4,349 Views)
