LabWindows/CVI
Is it possible to use UDP in CVI?
I have found an oldish example (v4.0.1) on the NI web site but the link is broken. Are there any other up to date examples?
(4,149 Views)
I was able to download the examples successfully from the following link
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3DDAB56A4E034080020E74861&p_node=DZ52164&p_source=External
Did you have errors while trying to download the example or when trying to build it? You would need to install the Windows SDK that is included with CVI in order to run this example since this example makes use of the wsock32.lib library. This library is part of the Windows SDK.
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(4,149 Views)
The error was trying to download the example, but some kind NI person, Efrat Strassberg, emailed the example to me. It built first time. So thanks heaps to all.
(4,149 Views)
I'm looking for a UDP example as well, could you email me the example? Thanks
(4,149 Views)
Here's an example program that shows how to implement UDP with TCP/IP Winsock layer. CVI 5.0.1 and earlier do not implement the UDP protocol. There is a simple instrument driver that implements UDP using the Windows SDK Winsock functions. If you have the Full Development System of CVI, and have installed the SDK package (by doing a custom install), you can use the instrument driver to create UDP applications
Enjoy!
Jeremy L.
Jeremy L.
(4,149 Views)
