LabWindows/CVI
Is it possible to use line feed in PlotText?
I was wondering if I could print two lines just below each other on a graph control using PlotText and a line feed within the text string? Unfortunately, I wasn't able to do so using 'bla\r bla' nor 'line1\n line2' ... Is there such a possibility?
Wolfgang
Message 1 of 8
(4,590 Views)
Accepted by topic author Wolfgang
Hi Wolfgang,
unfortunately the current PlotText function does not support any escape characters. This is a known issue and should be resolved with the next major CVI release. I am sorry there is no better solution for now.
Peter
Peter A.
Field Sales Engineer, NI Germany
Message 2 of 8
(4,574 Views)
Thank you!
Message 3 of 8
(4,569 Views)
In case you still want to plot two lines of text, you may find useful GetTextDisplaySize ( ) function, which returns the dimensions in pixels of a string in a given metafont. The text height can permit you to stack one text immediately below the other. Keep in mind that PlotText accepts coordinates in axis units, not in pixels, so you need to convert text height in pixels in the appropriate value in graph units.
Message 4 of 8
(4,567 Views)
Thanks Roberto for sharing this hint!
Peter
Peter A.
Message 5 of 8
(4,562 Views)
@PaSB wrote:
.... This is a known issue and should be resolved with the next major CVI release.
Nothing has changed so far, it's still the same in CVI2010 Smiley Sad. Is it going to be fixed as announced?
Message 6 of 8
(3,774 Views)
Hi Wolfgang,
I know that you're registered as a beta user. Have you tried this in the most recent beta?
I apologize for the incorrect information that you received, back in 2009. There was no commitment, at the time, of adding this feature in the "next major CVI release". I'm sorry that I didn't catch and correct this.
Luis
Message 7 of 8
(3,765 Views)
Hi Luis,
in PlotText the line feed character seems to work in the 2012 beta Smiley Happy
Thanks for sharing this news! You can add it to the 2012 readme - I haven't seen this announcement anywhere
Message 8 of 8
(3,745 Views)
