LabWindows/CVI
Is there a FileSavePopup?
Is there a Popup for creating a new file?
I am using an FTP client to get a file from the server and copy it to the client PC.
I want the operator to choose the directory path and the new file name for the transfer.
FileSelectPopup() works going the other way because the file already exists.
Thanks.
(3,522 Views)
FileSelectPopup() will work, change the Button Label to Save [VAL_SAVE_BUTTON].  This will allow you to select files that do not exist yet.
Message Edited by mvr on 07-06-2009 03:46 PM
(3,515 Views)
To be more precise, "Select" and "Load" will halt on error if you just type in a non-existing filename, "Ok" and "Select" won't (they will either return VAL_EXISTING_FILE_SELECTED or VAL_NEW_FILE_SELECTED depending on whether the file actually exists or not in the pointed directory).
(3,497 Views)
