LabWindows/CVI
Is there a discussion about the current FFT algorithm used by CVI 2012? Comparison to FFTW and Intel PPP would be helpful alsi if available.
One of my main application is pretty FFT intensive and therefore FFT performance is always on my mind.
 A few years back I recall a white paper (or similar) about CVI implementing the Intel MKL algorithm for improved performance. Is there a current white paper or similar for Intel processor based FFT under CVI 64-bit  for largish arrays (8 to 64 Gsample) ?
Also experiences with external FFT algorithms is appreciated. I have been using the now defunct Intel SPL for 32 bit apps (forever) and the Intel PPP for 64 bit apps (recently) but I am now having some deployment issues with the 64 - bit PPP packages. I have not determined if the PPP is to blame but it definitely seems to shut down execution profiling. ( I understand that the use of Intel PPP is not supported....)
(3,043 Views)
Hello blakney,
To my knowledge we do not have any white papers directed at Intel processor based FFTs under LabWindows/CVI 64-bit. Could you post a link to the whitepaper implementing the Intel MKL algorithm in LabWindows/CVI?
Jacob R. | Applications Engineer | National Instruments
(3,026 Views)
