LabWindows/CVI
Is there a function to know if a panel Handler handle something ?
In my panel handler managment, I'd like to know if a panel is already loaded or not.
Do I really have to manage my handler manually (set to -1 if discarded for example) or does CVI provides a way to know if a panel handler is "valid".
Thanks in advance...
(3,680 Views)
AFAIK there is no way to know if a particular (valid) handle points to an object still loaded. In the case of a panel you must manually set the handle to a non-valid value. You can embed both statements in a macro that discards the panel and disables the handle:
#define PanelDiscard(panel) { DiscardPanel (panel); panel = -1; }
(3,677 Views)
It could be a suggestion for the next version of CVI to manage handlers the way pointers are managed in C (i.e. a NULL handler if not loaded) ?!
Or there is a good reason to manage handlers this way (currently implemented in CVI) ?
(3,676 Views)
Hi Pifou, Roberto,
1) Thanks to Roberto for the macro. Easy, useful, elegant... well done Roberto... 5 stars.
2) Any Panel Function (GetPanelAttribute for example) should return an error if the panel handle is invalid. With that you can write your own PanelStillExists function.
(3,663 Views)
