LabWindows/CVI
Is there a generic USB API in CVI
We are looking for a simple solution to connect a Windows-based PC running CVI  via USB-interface to an embedded system implementing the device Philips ISP1181. The device is a slave to a u-controller bus and works as a bridge to the USB-interface.
(3,697 Views)
You should be able to set the device up using NI-VISA as a USB RAW device, and once configured properly, communicate with the device using the NI-VISA libraries in CVI.
http://digital.ni.com/public.nsf/allkb/E3A2C4FE42D7ED0D86256DB7005C65C9
(3,688 Views)
