LabWindows/CVI
Is there a method to include a ring into a table cell?
Hi.
In my project I need to complete the content of a table cell by selecting one from 3 values. To do that I think that I
should some how, put into a table cell a ring. Is there a possibility to do that?
Thanks.
(3,058 Views)
Hello tmaxial,
Currently the table control cells do not natively support ring controls. Instead, the cells can be strings, pictures or numerics, but as a workaround, I would check out the example program on the following forum post. When you double click on a table cell, the ring control appears above the clicked table cell, then the user selection is written to the table cell. It should be a good starting point.
Also, if you would like this feature to be considered for a future release of LabWindows/CVI, I would make a product suggestion on the following website.
Thanks, and I hope the example helps.
Wendy L
LabWindows/CVI Developer Newsletter
(3,047 Views)
tmaxial,
This feature will be included in the next release of CVI.
Luis
NI
(3,030 Views)
