LabWindows/CVI
Is there a swap()-routine in any CVI-Lib?
Hallo NI,
Several years ago I have worked with MS Visiual C++ and CVI5.5. Duing this time I developed a program which used the swap()-routine out of MSVC++-lib. Now I want to redevelop this program without using MSVC++. Is there any lib which uses the swap-routine in CVI 8.5?
(3,210 Views)
In CVI, there is no swap command, however, the Tools library provides the SwapBlock function to swap the contents of two blocks of memory. Another possibility is to define a macro.
(3,208 Views)
I have to apologize about my misspelling! It is a swab() routine not a swap(). However, the question is the same.
(3,203 Views)
How hard can it be? Let's see...
void _swab( char *src, char *dest, int n )
// Assumes n is even. Add appropriate code if it may be odd.
// Also assumes src and dest are not the same
int indx;
for (indx=1; indx<n; indx+=2)
dest[indx-1] = src[indx];
dest[indx] = src[indx-1];
Message Edited by msaxon on 26-04-2010 09:24 AM
Martin
Certified CVI Developer
(3,197 Views)
